07-27-2021 01:27 PM
Hey Hey!
We have a t7i we are trying to use for a photobooth. We're attempting to connect it to an AlienBee strobe with, with a hotshoe adapter and a cord. However, no matter what adapter or cord we use, the camera WILL NOT trigger the flash.
The menu system shows this (below) when the hotshoe adapter is attached, AND when there is nothing attached.
When I attach a flashpoint speedlight to the camera, it has no issues. I can access the menu, the flash fires, all is well.
Please help!
07-27-2021 01:59 PM
You don't have a center contact. You require an E-TTL flash that talks to the camera via the other 4 pins.
07-27-2021 10:04 PM
If you have a Canon speedlite or compatible, you can use it to trigger the optical slave built into the strobe. (I am assuming Alien Bee's have an optical trigger built in that allows them to fire based upon another flash firing and triggering them)
Rodger
07-27-2021 10:23 PM
Or even the cobra head flash.
07-27-2021 10:44 PM - edited 07-27-2021 10:44 PM
kv,
Can you set the pop up internal T7 flash for manual mode so that it won't always do a pre-flash for the E-TTL system? That exposure check flash would trigger the slaves before the regular full flash. With the Speedlites in manual mode, you don't have the problem with the pre-flash triggering the slaves.
Rodger
07-28-2021 09:00 AM
You can with the T6S. But some flash triggers can ignore the pre-flash.
