red and white stripes
rotomike
My brand new Rebel T5 shows red and white stripes like a flag and does not show any image.  Is the camera a faulty one or is there a setting that needs changing?
Mike
Now that's just not right.  That camera needs service, and soon.  Contact Canon U.S. Support at 1-800-OK-CANON.
14 REPLIES 14
Did you format the card in the camera before reying to use it?
Bob
I am running with no card it is used as a webcam and a computer polls the image from the cam.   The same thing that I did before and i have the menu set to use shutter without card.
Mike
Mike
I'll guess that you're exceeding the buffer capacity of the camera. I base that on the fact that the T5 is a somewhat stripped-down camera and that since it's brand new, it can't be the camera that you used that way (i.e., without a card) successfully in the past. Try it with a (fast) card in it.
Bob
@RobertTheFat wrote:
Mike
Either that, or the image sensor has overheated and been damaged.  The T5 is a stills camera, not a video camera.
i dont use it for video and takes a snapshot every 10 minutes i will try a card in it to see what happens.  What type and how big can it be?
Mike
just tried card and still red and white stripes.  did that from the get go out of box.
Mike
Okay,  What happens if you disconnect the computer, and just simply take a normal picture?
rotomike
That's what I'm doing just snapping pictures with camera only and just stripes. It has like maybe 10 total stripes red and white like flag horizontal.
I would ask you to pot a sample image, but it sounds like your camera's sensor may have failed.  But, post a sample, anyway.
