recommended fixed lens for 7d
ahering
I've been reading several reviews and comments about fixed/prime lens. However I get the feeling that uses for each are more related to cameras with full frame rather than camereas with cropped x1.6 sensors such as the 7D.  For example, 50mm 1.2 for events and most type of outdoor photography and 85mm 1.2 for portraits. So should I consider then the 35mm 1.4 for events and the 60mm 2.8 for portraits? My question probably is, should I adjust the type of lens I need just because of my camera type? Am I doing it right?
cicopo
You're on the right path. The one other thing to know about all of it is that the crop body also has a greater depth of field than a FF body at the same aperture. 30 mm is about the same as a 50 & the 50 is close to the 85 when comparing a 1.6 crop to FF.
1 REPLY 1
cicopo
