11-22-2019 04:30 AM
I've searched for the same issue, found those 2:
Which are simular to my problem, but mine is still another case.
So, situation:
But sometimes I see that the communication is lost. Sometimes it restores itself, but even then I have to redo my image sequence again. Sometimes it won't work anymore.
What could help is repower the camera. But when I turn off the Canon, the "Recording... Remaining images" messages appears:
It's not useful to wait until the message is gone. The only thing that works, is to remove the USB cable from the camera. The message will disappear and the camera will be turned off.
After this, I can communicate again with my camera.
Any idea what can cause this issue? And how I can solved it? Nothing that I just use the USB cable and not memory card.
If not clear, please ask 🙂
11-25-2019 03:32 AM
@shadowsports
Was also my idea. I've installed now a PCIe USB 3.0 board, as well as a power USB 3.0 extention cable of 5m.
I will see the results soon
11-22-2019 08:30 AM
Greeings,
So many factors here that might come into play.
What I think.
Buffering or transfer speed of the connection. First few pictures transfer , then the buffer fills and the images cannot be transferred fast enough to the storage source. The connection drops, fails and/or resets.
The camera only has so much buffer, I don't know what this is off the top of my head, but might you be exceeding the capacity with the transfer being unable to keep up with the flow of data? I don't use my camera like this, but believe this might be related to your issue.
~R5 C (1.0.7.1) ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, +RF 1.4x TC, +Canon Control Ring, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve ~Windows11 Pro ~ImageClass MF644Cdw/MF656Cdw ~Pixel 8
~CarePaks Are Worth It
11-25-2019 03:32 AM
@shadowsports
11-25-2019 05:38 AM
@WimVanCraen wrote:@shadowsports
@waddizzle
I use a tool wrapped around the canon dlls using the SDK commands.
I am not going to be able to help you when it comes to custom software. Good luck!
12-12-2019 09:57 AM
Seems like the hardware adaptation is fixing the issue for now. No communication problems occurred anymore
11-22-2019 12:56 PM
11-25-2019 03:34 AM
@Waddizzle
