10-25-2016 06:43 PM
10-26-2016 10:01 AM
Post a picture and tell us your settings, especially file size.
Is this on the LCD or in the file?
10-26-2016 05:11 PM
10-26-2016 05:14 PM
This photo was shot in RAW and it is straight out of the camera.
10-26-2016 05:21 PM
@pballaz wrote:
That is posturization not banding.
Posturization occurs when there is not sufficient bit depth to provide a gradual transition in subtle color changes.
What software did you use to convert the RAW file?
10-26-2016 06:36 PM - edited 10-26-2016 07:43 PM
I am using lightroom. When it is in Library you can see it. When it goes into develop I really don't see it. When I export it into Photoshop or anywhere else you can see it.
10-26-2016 07:14 PM - edited 10-26-2016 07:14 PM
@pballaz wrote:I am using lightroom.
You said that was with the default LR settings is that correct?
Check the File Settings on the export screen make sure it is set Quality 100 and the Color Space is sRGB.
10-26-2016 07:45 PM
That is how I have it set up. I am using lightroom. When it is in Library you can see it. When it goes into develop I really don't see it. When I export it into Photoshop or anywhere else you can see it.
10-27-2016 09:09 AM
Posterization, sometimes called banding, can be explained by too little information spread too far apart. Have you done all the latest upgrades to LR and PS? One thing you must not do if this posterization shows up is hike up the 'clarity' slider. This makes it worse. Increasing the 'grain' will reduce posterization.
You can also try to increase the color space to AdobeRGB. Some say that doesn't help but it does. Some shots benefit from it some shots don't. The color space in what you see is increased even though the color space outside the ability of your monitor is wasted.
Look at your histogram. It will indicate posterization especially in a processed jpg. The histogram is an invaluable tool.
10-26-2016 07:47 PM
