08-16-2021 03:03 PM
Hello, I left my EOS t5 on the shelf for 2 months with the battery in it. When I turn it on the shutter sounds like it is going non-stop. Help!
08-16-2021 03:12 PM
I think I have left my cameras longer than that, but I suggest you try to charge the battery, or put in your spare.
08-16-2021 04:06 PM
It has been sitting for years since this happened. Now it seems like it is working now. Thanks by the way. Is there up dates for these cameras? Someone told me to go to the third wrench and hit reset. There is no third wrench in the menu, only 1 and 2. I have never done any updates since I bought it new.
08-16-2021 07:49 PM
@Lawrence1956 wrote:It has been sitting for years since this happened. Now it seems like it is working now. Thanks by the way. Is there up dates for these cameras? Someone told me to go to the third wrench and hit reset. There is no third wrench in the menu, only 1 and 2. I have never done any updates since I bought it new.
Set the camera to P mode.
08-18-2021 10:13 AM
"There is no third wrench in the menu, only 1 and 2."
All functions are not available in all modes.
" I have never done any updates since I bought it new."
There is usually no "updates" required. You can have FW updates but you need to make sure they correct a problem you have. Otherwise they do not help you.
As to fully resetting the camera, any time you see unusual behavior a reset can be helpful especially if you set something and didn't realize you did.
08-18-2021 10:15 AM
"I left my EOS t5 on the shelf for 2 months with the battery in it."
If you don't intend on using your camera for extended periods of time, two months or so, always remove the battery.
