12-28-2016 07:38 PM
I bought T5i camera and EF-S 18-55mm lens.
each time I manually zoom in the object and try to take picture, the button doesn't work, the camera doesn't allow me to be too close to the object, what can I do?
Regards,
Mark
12-28-2016 07:53 PM
Your lens has a minimum focusing distance of about 10 inches. This is measured from the camera's sensor to the subject, not from the end of the lens. Are you trying to get that close?
12-28-2016 08:14 PM - edited 12-28-2016 08:15 PM
@ScottyP wrote:Your lens has a minimum focusing distance of about 10 inches. This is measured from the camera's sensor to the subject, not from the end of the lens. Are you trying to get that close?
Scotty is correct. If you have one of the standard camera kit lenses, then there should be something stamped on the lens that says "Macro #.## ft / #.## m" on it. That is the macro distance, or minimum focusing distance [MFD], for the lens. The MFD is given in feet and meters.
If your lens is in green square [A], automatic mode, then it will not allow you to take a picture until the camera has acquired and locked focus on a subject. This can happen if you're too close. It can also happen if you do not have sufficient light.
12-28-2016 08:58 PM
@yidianm wrote:I bought T5i camera and EF-S 18-55mm lens.
Regards,
Mark
Like this close? For this you need either a macro lens or a cheaper alternative like extension rings.
12-29-2016 03:48 AM
Scott,
yes, could you recommend the exact model number len compatible to the camera mount?
thanks,
12-29-2016 11:08 AM
@yidianm wrote:Scott,
thanks,
I'm not Scott, but the answer is: Canon EF-S 60mm f/2.8 macro ![]()
12-29-2016 11:15 AM
12-29-2016 01:40 PM
Thanks,
happy new year
