06-05-2014 08:17 PM
Hi all I have a XT 350D that as been wiped clean of all settings any idea how to reset them. In full auto it is at 1/60 iso
06-06-2014 12:02 PM
By saying the camera has been wiped cleaned I assumed it has been reset also. Do you mean that you only get shutter speed of 1/60 regardless of the enviroment? If so, make sure you are not in Tv mode.
Here is the copy of your camera manual: http://gdlp01.c-wss.com/gds/8/0900000278/01/EOSDRXT350DIM-EN.pdf
There is a lot to control on a DSLR, so I recommend you read it.
06-06-2014 12:44 PM - edited 06-06-2014 12:45 PM
"I have a XT 350D that as been wiped clean of all settings ..."
It is impossibile to "wipe it clean". If reset it will default to factory settings. Factory settings will work for most people.
This assumes a fully functioning camera that does not have a problem.
The above advice to read your maual is a good idea. Do it. ![]()
06-06-2014 06:30 AM
that would a shutter speed of 1/60 i have no idea what the iso is
06-06-2014 12:02 PM
06-07-2014 10:28 AM
Thanks for the download I have ordered a copy from amazon. I got this camera as a up grade from a point and shoot
06-07-2014 10:30 AM
06-07-2014 10:31 AM
