04-08-2022 05:34 PM
i got the camera to stream and make videos i know y room was kinda dark so I got the elgato key light, the camera with 100 iso/f3.5 and 5800k the video is still too dark when I turn up the iso I don't like how it loses video quality. i don't know what to do anymore outside when the sun is out it looks ok but it has this dark feeling to it like it has colors but its not enough. help is my camera having issues?
04-08-2022 08:08 PM
ISO 100 will typically be much too low for indoor scenes, unless you have a large quanity of light. Especially at f/3.5. If you cannot add any more light, and if that's the widest aperture your lens has, you'll need increase ISO.
Also, what shutter speed are you using? If you're at 1/120 second (e.g. shooting 60 fps), you should look at shooting at 1/60 instead (30 fps). That will let you cut the ISO in half.
Perhaps also look at a wider-aperture lens. e.g. an f/1.8 lens would let in four times the amount of light as your f/3.5 lens. So you could then lower the ISO by two full stops. Of course at such wide apertures, there is a tradeoff with having shallower depth-of-field.
04-11-2022 03:08 AM - edited 04-11-2022 11:52 PM
@loyariel wrote: DNA HRBlock Sign ini got the camera to stream and make videos i know y room was kinda dark so I got the elgato key light, the camera with 100 iso/f3.5 and 5800k the video is still too dark when I turn up the iso I don't like how it loses video quality. i don't know what to do anymore outside when the sun is out it looks ok but it has this dark feeling to it like it has colors but its not enough. help is my camera having issues?
Try manually focusing or experiment with some different auto focus modes. If you're using a tripod make sure to turn off image stabilization. And remember that video is much more forgiving of less than perfect focus than still shooting is.
