flash not working on 1dx mkII
tizianmast
The title says it all, i have a very simple flash, that fires when it gets the middle pin and ground thingy from the hot shue connectet. it works on my other cameras, but somehow not on my 1dx MKII, in both live view and not. I allready cleaned the contacts.  It worket at some pont, but not anymore. the speedlite setting is activated.
6 REPLIES 6
deebatman316
What speedlite are you using FULL NAME please. Is it Canon or a 3rd Party manufacturer.
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
i tried with a culmann sl28, but this fires by shorting the midle pin and to ground(the outside of the hotshue, it is a two pin flash) and i tried with the metz 40af-4c this has more pinns, but still fires the same way. i can fire both flashes with a wire or another camera
What happens if you use a Canon speedlite.
-Demetrius
wq9nsc
In addition to setting the flash firing to enable under external speedlite control, you may have to set the flash mode to manual instead of ETTL in the 1DX II menu setting given these flashes may precede the introduction of ETTL.
Rodger
The External Speedlite Control Menu doesn’t work with fully manual Speedlites. In fact E-TTL is grayed with one mounted. Older Canon Speedlites released prior to the introduction of the Speedlite Control Menu. Often have most options unavailable or grayed out. Making them unselectable or unchangeable from the camera’s menu screen. Below is an example picture of an older Canon Speedlite mounted. The particular Speedlite is the 420EX. As you see most options are not visible or grayed out. Only FEC and 1st & 2nd/ Rear Curtain sync are available from the camera’s menu screen with this speedlite. Other speedlites such as the 550EX have curtain sync grayed out. That must be set on the speedlite itself.
-Demetrius
Friends and Family
