09-09-2014 10:07 AM - edited 09-10-2014 07:28 AM
HI! I have a problem with the camera which shows card error in the LCD panel. I tried with different SD but the camero shows the same error message: No access to the memory insert or change the cerad or format it with the camera. When I try to format the SD with the camera the following message appear: No possible to format the card, change the card.
Thanks for you suggestion.
Best regards,
Jorge
09-10-2014 09:57 AM
It needs Canon service. ![]()
09-10-2014 09:57 AM
09-10-2014 10:52 AM
Thanks!!
