05-28-2013 09:27 AM
Bought my Digital rebel 2004- love it
Bought my new laptop - windows 8
I can't download my pictures. I read on the forum that I can go to my menu button on my rebel and go torint/PTP- wil this work for me?
05-28-2013 01:52 PM
05-28-2013 11:47 AM
The simplist way to get around these problems is to buy & use a card reader. They aren't expensive & allow you to download to just about any computer with a USB port.
05-28-2013 12:11 PM
will any card reader work -- is one better than the other?
what about changing on my camera to PTP ( whatever that is-- ass-u-me it's an easy change) then it's done one time and forever without having " another " piece to deal with.
Ell
05-28-2013 12:22 PM
Give it a shot and see if it works... but doesn't your laptop have an SD card reader on it? I find that to be easier than pulling out a cord and my camera.
And yes, any ole card reader should work, but if your laptop has USB 3.0, just make sure you get a 3.0 card reader.
05-28-2013 12:43 PM
to be honest.... I took a quick look at my laptop and the slot for a memory card looked smaller that the card I use on my camera-- I'll have to double check when I get home from work. ( canon uses a " larger " memory card than my wifes HP quick shot ... the slot looks like it would fit that one )
thanks for the input
ell
05-28-2013 12:57 PM
What laptop is it?
05-28-2013 01:00 PM
It's very likely the original Rebel uses a CF card and most current card readers will have no trouble reading it including CHEAP ones. As for the other setting I've checked my 20D manual on my laptop & the PTP setting is for direct printing but worth trying since computer OS systems have changed since those days. t
05-28-2013 01:02 PM
A Dell- - pretty standard model - upgraded processor
05-28-2013 01:07 PM
Sorry, you're right, the 300D had CF.
OP: You'll need a card reader to read directly from the laptop. Try the PTP first before buying a reader though.
05-28-2013 01:10 PM
I won't be screwing up my camera by changing that right? ( can u tell I'm not a computer kinda guy ? )
ell
