corrupt movie files
tbakersv
I used a Rebel T 5 as a stationary camera for some music performances. All of the files showed up on the flash card but over half showed that there was spaced being used on the card but the length of the clip was absent. None of these clips will play. I have tried software and renamed clips to no avail. Any suggestions.
3 REPLIES 3
Tronhard
VIP
VIP
First question:
What exactly was the card you were using?
cheers, TREVOR
I believe it was an Extreme Pro Sandisc 64 G or a Lextar XC 2, 128 G
Waddizzle
Your memory cards may be the problem. You should only use UHS-I memory cards. Use the only the full size cards. For some reason, My T5 did not like the big capacity SDXC memory cards. Stick to 32GB, or less.
