07-14-2023 11:06 AM
I'm using an EOS Rebel T7 for work meetings in Zoom / Microsoft Teams. The connection works great to a Macbook (USB-C Cord, EOS software, etc).
I'm still learning how to use the camera --
Besides using "Movie Mode", what camera settings would you suggest for web conferencing for work?
Thanks!
07-15-2023 01:01 PM
Concerning white balance, I would use auto white balance white priority (AWBW).
07-14-2023 11:09 AM
The camera should only be set to Movie Mode when using the EOS Webcam Utility.
07-15-2023 12:36 PM
Thanks -- what I'm asking is if there is anything else (besides Movie Mode) that someone would suggest for webcam use?
Anything like lens aperture, white balance, etc -- I'm new to this, so not sure if there's an obvious list of settings one would use while on Movie Mode
07-15-2023 01:01 PM
07-15-2023 05:32 PM
Suggest setting the camera mode dial the the Green [A+] mode until you become more familiar with how to use the camera. Set the lens AF/MF switch to AF, if it has one. If the camera has and IS switch, leave that turned off because I suspect the camera is on a tripod or some other means of support that stops it from moving.
