03-08-2013 11:49 AM
I'm suddenly having trouble connecting my iPad4 and iPhone5 to my 6D in direct-connect WiFi mode. I haven't been able to connect since updating to iOS 6.1.2 with either. I can still connect in "infrastructure mode" if the camera is connected to my work or home network first, but can't direct-connect.
Anyone experience the same problem? Or has anyone been able to connect successfully with iOS 6.1.2.
Thanks for any help!
Jim
03-08-2013 12:36 PM
My Bad. Figured a solution out. I had to "forget the network" on each device and re-setup each of the device configurations on the camera to issue new passwords. Was then able to re-connect each device and get them connecting again.
Problem solved. Oh, one trick: if any of you have multiple devices (I have an iPhone and iPad), you want to have two corresponding settings on the 6D: one for each device.
Jim
03-08-2013 12:36 PM
Jim
