04-29-2015 08:36 AM
04-29-2015 10:14 AM
Alway, always the lens. Lenses are where its at. Comparing a 100-400mm to a 400mm DO is even more compelling to go for the lens.
04-29-2015 11:23 AM
04-30-2015 07:33 PM
I always assumed lens upgrade first. In this case I was impressed by the new features of the 5DS R because I photograph small birds, often in trees, often at a distance of 30-50 feet, and almost always moving around. I thought the 61 point high density reticular AF might be quick enough to get a photo (that my current set up can't get) and with a file that would allow severe cropping which would make up for the distance.
On the other hand, photographing birds in riparian areas where there is usually poor lighting might suggest the better lens is the answer.
That's basically why I thought to ask others.
04-30-2015 07:33 PM
04-30-2015 07:44 PM
05-04-2015 09:26 PM
@ebiggs1 wrote:Alway, always the lens. Lenses are where its at. Comparing a 100-400mm to a 400mm DO is even more compelling to go for the lens.
Thanks Biggs and guys, good to know. I'll file away for future reference that a lens upgrade is always the better.
05-05-2015 09:22 AM
Oh, man, I can see right now I should have qualified that statement. You do have to use some common sense here.
Obiviously going from a EF 24-70 f2.8 to a EF-S 18-55mm would not.
