07-08-2026 06:20 PM
I had a Canon Rebel camera that kept producing weird dots in photos so I purchased an EOS 2000D. I am having the same exact issue with this camera. Recently went to an air show and took 659 pictures with 2 different lenses. Dots appear in all 659 pictures in the same position. Since I used 2 different lenses, there has to be an issue in the body of the camera. When I remove the lens, I do not see any debris on the mirror. I try to keep the camera at a constant temperature to avoid any condensation. Any ideas as how to correct this issue? I saw the same dots in another post and they were in the same position as well.
07-09-2026 08:59 PM
VideoMaster,
Since dots appear in your Playback, I think we can eliminate the transfer process or computer as the source of your problem.
I went back a re-read your original post. You didn't say that the spots appeared in the same place on both cameras. That's just the way I mistakenly read it.
I agree with Newton. It looks like you've got spots on your sensor, and it needs cleaning.
Steve Thomas
