Wandering focus point box. Model 700D (Rebel T5i)
mike21
Enthusiast
From time to time, including sometimes when I have just switched on, the rectangular focus point box on the LCD screen appears in the bottom left corner instead of centre - pressing.OK brings it back to the middle. When I press the AF point selection button (+) the ring of small blocks shows only the centre on lit up, which is as I wish. I usually use the viewfinder for shooting and am concerned that the focus point may not be in the centre - although it always shows it there - without me knowing. Settings are flexizone single, one shot, continuous AF. How can I ensure that this focus box movement does not occur - I do not think that I accidentally touch the LCD screen to cause it.
mike21
Enthusiast
So long as the viewfinder focus is not affected I will put up with the wandering focus point on the LCD screen. It is just an irritation. Thanks to everyone.
8 REPLIES 8
kvbarkley
VIP
VIP
When the focus box shows up in the corner, what happens when you put the camera on a subject in the center and press half-way?
With the box in the corner when I press the button half way it stays in the same place and turns green, as I would expect. I cannot find a solution in the full manual or David Busch's field guide, although perhaps the solution is there but I'm just unable to see it.
I saw nothing in my T6S manual. I was kinda hoping that it showing up when you first turned on was a fluke and it would snap back when you tried to focus.
Looks like the bug is that it wanders around on its own. If you can't reliably reproduce it, it will be hard to track down.
The user manual is your friend. If you don't have one for your camera, you can download it from the Canon Web site. Even if you do, it may be an abridged version; the one you download will be complete.
Bob
Actually, you can download the abridged version, too. You want the "Instruction Manual", not the "Basic Instruction Manual"
diverhank
I don't have a T5i camera and not any camera with me to verify but I think the LCD focus box and the viewfinder focus box are unrelated since the liveview focus and the regular focus are different.  On my non-touchable 7D Mark II, they are unrelated, I know that for sure.
Diverhank's photos on Flickr
mike21
Enthusiast
If you want to ensure the center focus point is always selected, then you need to use one of the Creative shooting modes, not one of the Basic shooting modes.  I suggest that you use "P" mode, which seems to be the best to learn how to use a Canon DSLR.
