03-03-2019 09:48 PM
I have an old Rebel 2000 film camera and a newer Rebel T3 digital. I have a couple of EF-S lenses that I would like to be able to use on the film camera. What kind of adapter do I need?
Thanks.
03-03-2019 10:01 PM - edited 03-03-2019 11:32 PM
@DrxJdaddyxx001 wrote:I have an old Rebel 2000 film camera and a newer Rebel T3 digital. I have a couple of EF-S lenses that I would like to be able to use on the film camera. What kind of adapter do I need?
Thanks.
There is no adapter available to mount an EF-S lens on an EF mount body. This is by design. You need EF lenses, exclusively, with the Rebel 2000 35mm film camera.
The EF-S mount was developed for digital cameras that used an image sensor that was smaller than a full 35mm frame. The full frame sensors were expensive to manufacture, and pretty much still are.
[EDIT]. Because the APS-C image sensor is smaller that a full frame sensor, the image circle projected by an EF-S lens would [not] fully cover the entire 35mm frame.
03-04-2019 10:49 AM
It is possible to do but I am not going to tell you how since it is an exercise in futility. I am sure you can find the 'how to' on the ole inner web.
03-04-2019 09:51 PM
03-04-2019 10:25 PM
The EF-50 / 1.8 would be a good inexpensive start.
