07-11-2017 12:19 PM
07-11-2017 02:18 PM
Any EF Canon lens should work fine. Your third party lenses may have firmware issues, but I doubt that they can be corrected for such an old camera.
07-11-2017 03:44 PM
I think they all will work. It is usually newer camera models that don't work. Older models don't seem to have that trouble.
If they don't, however, they won't and never will as like kv says, you aren't likely to be able to up/down grade them!
"I've got the entire Sigma art line ..." Wow, I am highly impressed. They are very fine lenses aren't they? The 50mil Art is said to be the sharpest lens made. I believe it. The 35mm is no slouch either! I have the 35, 50 and 85mm Art.
07-11-2017 04:34 PM - edited 07-11-2017 04:35 PM
I was thinking that Sigma might gave up backwards compatibility to work with newer cameras.
You want sharp?
https://www.lensrentals.com/blog/2017/07/experiments-for-ultra-high-resolution-camera-sensors/
07-12-2017 12:04 PM
Well I can't say with any certainty as I don't have and never had a Rebel G. That is just my guess which may be pretty worthless. He will just have to give it a go.
07-12-2017 12:18 PM
Yep, suck it and see!
07-21-2017 05:10 PM
07-22-2017 03:17 AM
I am with you on most of the Siggy Art lenses but there is no way the Siggy 24-70mm is better than the Canon ef 24-70mm f2.8L II. No by a long shot.
Two Canon lenses have no competition and that is the afore mentioned 24-70 and its big brother ef 70-200mm f2.8L II.
I consider these to be the best zoom lenses made.
07-21-2017 05:11 PM
07-25-2017 10:52 AM
