02-06-2023 08:08 PM
Hello there!
My name is Erica and I do photography mostly as a hobby. I have had my Rebel for almost 8 years now, It is my baby. However, it is time for an up grade. I do mostly portraits and nature fine art photography. I don't want to spend over $1,000 or so - but I do want to upgrade to mirrorless. I have been having the hardest time figuring out which camera is best for me. Here are the top few I am thinking of:
- EOS M50, Mark II, Mirrorless (I tried this one in the store and it felt so small! I think I would rather a full frame)
- EOS RP Mirrorless
Or another one?? I want to be able to enlarge my prints quite a bit. I attached some photos of my photography style for reference. Any help would be HUGGGEEEELY appreciated. I have spent months trying to figure it out and haven't gotten that far!!!
P.S. I also love using my 85mm. So I will prob get a similar lens 🙂
02-06-2023 08:23 PM
At $1,000 you'll find that will be be all spent towards a body. What lenses do you currently have? That will help in determining what to suggest. There are adapters though for the R-series mirrorless cameras where you'd be able to use your existing lenses.
Camera's other than the EOS RP that may suit your needs are either the EOS R10 or EOS R7. Though the latter is above your current budget.
I would lean away from the EOS M cameras as they don't seem to have much of a future.
02-06-2023 11:37 PM
I would wait a couple days and see what the R50 is all about, which Canon is supposed to announce Wednesday. Its projected pricing is only slightly above that of the M50, but it remains to be seen exactly what kind of camera it's going to be (e.g. will it be a true M50 successor, or more of an M6 successor - i.e. sans EVF).
02-07-2023 12:39 AM
Since you are used to the cropped sensor on the Rebel, the R10 would a fit seamlessly into your workflow. However, I'd use this chance to go full frame and would go with the RP. I would get body only for either and get a EF to RF adapter and use your current lenses for the time being (assuming you have mostly EF and not EF-S lenses).
Definitely take a look at the RP in the store to see if you like the form factor in terms of handling.
02-07-2023 08:38 AM
Based on your postings it doesn't look like your Rebel is limiting you in any way. Don't get caught up in upgrading for upgrading sake. Decide where you are lacking and look for a camera that addresses that deficiency.
02-07-2023 11:40 AM - edited 02-09-2023 11:47 AM
The top best points made:
" Don't get caught up in upgrading for upgrading sake...."
"... the EOS M cameras as they don't seem to have much of a future."
You didn't mention what lens(s) you have. Lenses are where it's at not the camera. And FF is not a good idea just because it is FF. All cameras are FF, in the sence you get exactly what you see in the viewfinder or LCD screen. The FL of the lens you are using just has a slightly different angle of view (AOV). THAT'S ALL!
"It is my baby."
It still is looking at your work.
This goal is a good reason for upgrading if you can't enlarge to the extent you desire currently. A FF camera with a larger MP count can help with that. You didn't mention which Rebel you have did you? Being 8 years old I suspect t has about an 18 MP sensor. You will want a newer camera that has a bigger sensor count than that but enlarging is not just limited to MP count. The entire electronics in the camera can bear on it too. As you might expect newer tech is almost always better. Eight years is an eternity when talking computers or electronics. Forget the M series and look towards the R series. If it's out of the budget today save up for a while because R is where it going.
02-07-2023 12:16 PM
When people say that I think the assumption is that an RF mount camera will come along that is a viable replacement for the EF-M cameras, especially the M50. But it's not clear that that will ever happen. We should get a clearer picture of whether it might with tomorrow's announcement of the R50.
02-08-2023 07:23 PM
Thank you for your input. It is honestly so helpful.
I have a EF-s 18-55mm and a EF 75-300mm.
I noticed that canon just came out with a number or new R series. Between the EOS R50, EOS R10 and EOS RP - which do you think would be best to go with? Thank you in advance!
02-08-2023 07:24 PM
This is great advice. I just took a look. The R50 looks great. Do you know much about the difference between R50 and R10?
02-08-2023 07:25 PM
What are the benefits of full frame? I have one EF and one EF-S lens. But I think I can get an adapter for both?
