02-08-2023 02:53 AM
Hello, i have problem with my new canon r6 camera.
When i shoot on the cyclorama only. How i can fix it? Problem with sensor?
02-08-2023 05:43 AM - edited 02-08-2023 05:43 AM
That seems like you are using electronic shutter mode. Switch to mechanical shutter mode or 1st curtain shutter mode.
The reason is flickering light source.
02-08-2023 06:10 AM
It was 1st curtain shutter mode by default. I will test it with mechanical mode. Thank you
As a light i use Aputure amaran 200d, it must be not so bad light
02-08-2023 08:39 AM
Or change shutter speed.
02-08-2023 03:14 PM
thank you for reply.
At this photos with vertical lines shutter speed from 1200 to 3200.
02-08-2023 03:45 PM
That's most likely the issue then. At such a fast shutter, this can indeed reveal issues with flickering lights.
As an experiement, reduce the shutter say down to 1/200s and see if it reduces/ellimates the issue.
02-08-2023 11:42 AM - edited 02-08-2023 12:22 PM
In looking at that product, it appears to be marketed more as being a video light. Though it does mention can be used for photography as well. I wasn't able to find any details though regarding frequencies that could lead to flicker. Do agree with Peter's recommendation on using different shutter speeds.
02-09-2023 08:22 AM
Problem was with shutter mode. Changed to mechanical and everything ok! Thank you
03/02/2023: New Firmware Updates Are Available:
EOS R7 - Version 1.3.0EOS R10 - Version 1.3.02/07/2023: New product announcements!
