05-02-2021 03:51 PM
Hello:
This is about the Manual exposure mode in EOS 6D. Sometimes it would be convenient to automatically adjust the aperture when the speed is changed and vice versa. For example, I set the aperture and speed, take a shot, and than decide I need more depth of field, so I dial the aperture up 1.5 stops. I'd like the camera to automatically dial the speed down by the same amount, In other words, I'd like the camera to keep the same EV (and keep the ISO setting).
I know this feaure is available in Program mode, but is it possible in Manual mode?
Thank you in advance for your answers!
05-02-2021 04:01 PM
No. Manual is manual; in that mode, it is up to you to control all settings.
Sounds like you should be using Av (aperture priority) mode.
05-03-2021 11:02 AM
Sounds like Av mode. You set an aperture in Av. The camera sets the SS. You decide you want a 1 and a half stop change and the camera now selcts that corrected SS.
05-03-2021 12:10 PM
Hi Ricky:
Av is not ideal: it will set the speed differently for each shot. Thank you for your reply.
OR
05-03-2021 12:13 PM - edited 05-03-2021 12:14 PM
Hi EB:
Thank you for your reply. Just like I mentiond to Ricky, Av is not reliablale: it will set the speed differently for each shot.
Even old clanky mechanical Hasselblad has the feature I am asking about. Maybe Canon will eventually add it to the prosumer cameras.
Cheers,
OR.
05-03-2021 12:29 PM
"...it will set the speed differently for each shot."
Correct! If you change the aperture (manually in Av mode) you must change the SS by the equivalent amount to maintain the same exposure. Whether you do it manually or the camera does automatically is immaterial. If you want the exact same exposure that is.
05-03-2021 02:17 PM
It sounds like you want ultimate control. Thus, you'll need to use manual mode. Just get familiar with the exposure triangle so that if you need to adjust aperature, you can adjust shutter and/or ISO to compensate.
Also ensure that your camera settings will all be using the same increments (e.g. 1/3 stop). Makes things much easier when doing compensation adjustments.
05-03-2021 06:33 PM - edited 05-03-2021 06:35 PM
@FPP wrote:Hello:
That type of functionality is not available in M mode. The camera can be set so that it can control all of the legs of Exposure Triangle, any two legs, any one, or none.
As you have already noted, the behavior that you wish to have is available in P mode. Use that mode, and dial in an ISO.
05-04-2021 11:28 AM
Thank you, @Waddizzle.
I wonder if professianal grade DSLRs or mirrorless have this feature... But it's purely academic, as I like my 6D and going to stick with it for a while.
05-04-2021 12:44 PM
They don't. Your only options are to use full manual where you control all aspects of the exposure triangle. Or, use another mode where one or more aspects are controlled for you.
