Tethering LR
joannascipior
I have a problem with tethering, when I start tethering using tether cable, my camera canon 5d mark iv is dedected, but images aren't seen on LR only on my camera. I don't know what is wrong.
27 REPLIES 27
jrhoffman75
You can call Adobe or start an online chat with them.
ebiggs1
Which version of LR do you have?  You are using a known good USB cable? You did disable EOS Utility? They don't play well together.
EOS 1DX and many lenses.
joannascipior
I have Adobe subscription so I have the latest LR, theter cable super high speed, e342987 orange:) first I didnt have Eos utility when I was try tethering, when it wasnt worked I installed EOS
I use the same USB cable.  OK, does EOSU tether for you?
joannascipior
Yes, EOSU tethers
Latest LR and known good cable, EOSU works.  I think you need to get a hold of Adobe.  It sounds like an Adobe issue since we know with your set up it is possible.
I know Adobe can be a challenge with support so I wish you good luck. I wish I could help more! I don't have a 5D4 but I do tether my 1DX and it works perfectly. Anyway good luck with Adobe. Sorry.
joannascipior
Thank You!
@joannascipior wrote:
Yes, EOSU tethers
The EOSU can automatically startup when you connect a Canon DSLR camera and power it up.  Make sure EOSU is not running when you want to tether to LR.
jrhoffman75
OP said “first I didnt have Eos utility when I was try tethering, when it wasnt worked I installed EOS”
