T7i disables mic when HDMI is connected
DrDerrp
I am using an external monitor to shoot some video and do live recordings.  At least I am trying to.  Whenever I plug in an HDMI to the camera, my mic stops working (onboard mic and external).  Any way to fix this?
14 REPLIES 14
kvbarkley
VIP
VIP
I don't think so, I believe it is feedback protection.
Waddizzle
Doesn't your recording monitor have a separate audio input?
Not that I know of.  The camera will still record audio, but I don't want to record it. I want LIVE audio like a mic should be doing so I can use the camera as a video camera for live broadcasting.
On the lower-level cameras Canon disables the audio out of HDMI for recording to prevent feedback when you use a TV as a monitor. You can't disable this feature.
Of course, the camera records audio internally.  It just does not have an audio output.  HDMI output is strictly video, and this is true for every camera I have used, including myCinema EOS C100 video camera.  Audio is a completely separate signal.
Alright, so how to I get audio output to work then?
You don't because you can't.  There is no audio output.  Period.  Use an external microphone.
I have an external microphone.  It's plugged in, it's 3.5mm. It has it's own power source.  I plug in the hdmi cord, mic stops working.
Plug the microphone into your recorder.  Good luck.
