04-25-2018 04:32 PM
Hi guys, I use a Canon T7i for filming which isn't bad for beginners like me but I just run into an autofocus problem, when there's a group of people it keeps changing all the time tracking people faces and the focus is not good at all, how can I deactivate that or change that to have a good autofocus, hope someone can help me with this issue , Thank you
04-30-2018 09:57 PM
Hello JPCG,
To turn off the Face Tracking feature, you would have the camera in the movie shooting/ camera mode. Then go into the Menu and into the AF Method sub heading. Yours most likely has Face Tracking enabled. You might wish to try Smooth zone instead to see if this gives you a better effect when shooting.
04-28-2018 07:13 PM
Are you having focusing problems capturing video?
There are a couple of things that you can do. One, hire a camera operator because the camera has a mind of its’ own. Two, read up on shooting video in the instruction manual.
BTW, the simplest cure is to focus the lens, and then turn of AF/MF switch on the lens.
04-30-2018 09:57 PM
Hello JPCG,
05-03-2018 04:52 AM
thank you, it works perfectly with your suggestion
