T6i and external monitor won't work
mderksen
I have a T6i and when I connect it to an external HD monitor using the HDMI out port no image is displayed on the external monitor. the camera acts like nothing has changed.
I went into the camera settings and set the Ctrl over HDMI to Enable, but that didn't change anything.
Am I missing something?
18 REPLIES 18
jrhoffman75
Did you press the blue playback arrow.
kvbarkley
I would try a different cable.
yes I have tried these steps using a few different monitors.  I'm beginning to think the port on the camera is defective 😞
I asked if you tried a new *cable* not *monitor*, and yes, if a new cable does not work, it is probably the camera. The "control via HDMI" has nothing to do with this. That simply allows you to control the camera with the TV remote - which I have never had success with, though my T6S displays on my HDMI TV's just fine.
Have you tried the composite video output?
Sorry my response was to the first person who responded. and I also tried multiple cables as well.
I don't believe my camera has a composite video out option. the HDMI is the only one I can see, unless I'm missing something which is possible.
It does have composite out with Canon cable. Plugs into USB port.
oh interesting. I don't have one of those cables so I'll have to go pick one up. it's worth a shot, Thanks!
Is your LCD still active when you plug in the HDMI cable?  It shouldn't be.
Sarah1989
I'm having the same issue and my LCD is still active even while the HDMI cable is plugged in. It was working fine yesterday. Could it be the port or the cable?
