T6i Charging??? HELP!!!
RT87
Hello...
Just got a T6i.
When charging, is the charger supposed to blink orange/yellow or should it stay a solid color?
When first putting the battery on the charger out of the box, how long does it take to fully charge?
My camera is a canon factory refurb, and I cannot tell if the battter or charger is working correctly. I've contacted
canon tech support.  One rep said the charger should remain a solid color another said it should blink till the charge light
turns green.
Please let me know....
Thanks
5 REPLIES 5
Waddizzle
@RT87 wrote:
Hello...
Just got a T6i.
turns green.
Thanks
While I have not used the T6i charger, every other Canon charger that I have used blinks red/orange until it turns to a steady green color, which indicates a full charge.
How long does it take?  An initial charge may take a few hours, or even overnight.  After that, 2-4 hours should do it.
Thanks...
I think Canon sent me a bad battery with my camera.
Its been charging for about 10 hours.  Still blinking.  I figured it should have at least enough juice
to turn the camera on by now....no dice.
I've called them and they are sending a new one.
Thanks for your reply!
RT87
@RT87 wrote:
Hello...
Just got a T6i.
turns green.
Thanks
With most Canon chargers the blinking pattern tells you how the charging process is progressing. One blink means it's just getting started; two blinks means about halfway; three blinks means 3/4 done; steady light (with or without a change of color) means fully charged.
Bob
Hello...
Just received my new battery.
When the battery is in the charger, it stays solid orange until it flips to green.
At least I know my new T6i works just fine!!
Mine stays yellow, too. Just tried it this morning.
Friends and Family
