03-31-2017 07:34 PM
03-31-2017 07:45 PM
" . . . I added the super wide angle lens to the regular lens, just to see . . ."
Something about that sounds a little odd to me. I'm not aware of any Canon branded camera kits that come with a "super wide angle" anything that can be added to the standard camera kit lens.
Make sure that the standard lens AF/MF switch is in the AF position. The camera needs sufficient light and a minimum focusing distance to properly focus with different lenses. If your camera is a few months old, then it should still be under the Canon one year warranty. Contact Canon U.S. Support at 1-800-OK-CANON for the best advice.
04-01-2017 08:12 AM
Try the steps in post 3 of this link.
https://community.usa.canon.com/t5/Lenses/Autofocus-not-working-18-55mm-lens/td-p/138114
04-01-2017 09:21 AM
"I added the super wide angle lens to the regular lens just to see what the difference would be."
The difference would be you screwed up the focus mech of your lens. Never screw auxiliary lenses on the front of a Canon lens. Very bad idea.
Call Canon Support and tell them exactly what you did. They will instruct you on how to reset the lens if possible.
04-01-2017 10:23 AM
@ebiggs1 wrote:"I added the super wide angle lens to the regular lens just to see what the difference would be."
I share your opinion of auxiliary "lenses", but I can't imagine how using one could actually damage the (real) lens.
04-01-2017 11:24 AM
Some would argue that the additional weight can be harmful to the AF motors, especially for a lens that telescopes and rotates the lens barrel to focus itself. I don't see how the added weight is very different from a lens hood, but I suppose it could.
04-01-2017 12:10 PM
My vote would be the OP may have bumped something with the aux lens or sideways loaded the lens when attaching the aux lens and that kicked the main lens off center.
I am more confused as to why the diopter was maladjusted simultaineously with the main lens problem.
04-02-2017 11:55 AM
"... I can't imagine how using one could actually damage the (real) lens."
ROBERT, you really have to ask?
"...the OP may have bumped something with the aux lens or sideways loaded the lens when attaching the aux lens and that kicked the main lens off center."
In the DSLR classes I used to do, I bet fully half of the Mom's bought their gear from Amazon or Costco where they had these totally useless and worthless packages. All sorts and manner of junk to use on your brand new Rebel. I am really surprised that Canon does not instruct its authorized USA dealers to not assemble packages that have the potential to damage the lens or camera. They should!
Some of those add-on lenses are made of iron I think. They are so heavy! Twist it too much or sit the camera down a bit hard. Bump against you side while on the neck strap. Funny they do warn you about the neck strap not holding heavy lenses. It isn't difficult to see how the damage can occur.
Even if you didn't get a damaged lens out of the package, the package itself is still junk. A crappy tripod is usually included which in itself could be a factor in a damaged camera.
It is easy to see why folks fall for these packages as it seems Canon is on-board with them. After all it is from an authorized Canon USA dealer.
04-01-2017 09:23 AM
04-01-2017 09:40 AM
Adjust the viewfinder diopter. A small knob next to the viewfinder.
