T5i black screen
Kimmy_a72
My camera was fine one day; then the next time I used it, there is an issue. When I turn it on, it says senor cleaning, then the screen goes black. If I press the ISO button, the menu won't come up. I have to press Info twice then Q to get it to come up. If I take a picture, it will not do an image review. I've checked the menu option for image review and it is turned on for two seconds as it's always been. Has anyone dealt with this? I would appreciate any help. Thank you!
Hazel_T
Hi Kimmy_a72,
The camera can show a few different displays and one of them is a blank screen. If the camera got switched to that screen it would act similar to what you are describing. You can check that by turning on the camera and repeatedly press the Info button. Each time you press the Info button the camera will cycle to the next display type it can show. When you see the one you prefer stop pressing the button and the camera will remember the screen you left it on. When the camera is set to the blank display it will not playback photos, but when it is set to one of the displays that shows information your photos should be played back after you take them.
If the LCD is going blank without pressing a button that is a sign the LCD is malfunctioning. The Info button is the only one that can make the rear LCD blank. In that case we would recommend sending the camera in for repair.
Canon U.S.A., Inc. has created a new online repair portal that allows you to set up service in a few simple steps. The repair portal gives you the ability to set up service for multiple pieces of equipment at once, and to receive a repair estimate in the majority of cases, depending on your model and issue. The portal also allows you to upload images or videos that will assist us in repairing your product. You can also select how you wish to be notified of the progress of your repair. The portal's service history section allows you to view all services that have been performed on any of your camera or video products since January 7, 2020.
Please follow the link below to access our online repair
https://mycanon.usa.canon.com/signin
Instructions for Accessing and Using the Online Repair Portal
You will need to access or create your My Canon Account.
If you already have a My Canon Account and your product is already registered, simply click on the “Get Repair Services” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you have a My Canon Account and your product is not registered, you must register your product first. Click on the “Get Repair Services” link on the left menu, then click on the “Register Product” link on the right. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you do not have a My Canon Account, you will need to create one. After you create your account, click on the “Add Product” link to register your first product. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
Once you have completed the repair request, you will have an opportunity to print a copy of the request for your records. This request form will also contain shipping instructions and an address label that you will attach to the outside of your shipping box when mailing your equipment for repair.
4 REPLIES 4
Hazel_T
Hi Kimmy_a72,
ebiggs1
" In that case we would recommend sending the camera in for repair."
The T5i is still a serviceable model?
EOS 1DX and many lenses.
Looks like it based on the Canon service request page.
Thanks everyone. It must be a malfunction. Nothing I’ve tried to do has made a difference. I’ll be contacting Canon to see if it can be fixed.
