07-08-2016 12:28 AM
07-08-2016 06:46 AM
Due to your short time line what about a rental camera for te event?
07-08-2016 08:37 AM
07-08-2016 10:26 AM
I have never heard of a bent pin in a SD card slot. CF card slots are notorious for bent pins but not SD.
Only Canon can tell you how much it will cost but I think $200 is a close figure.
BTW, all DSLRs that use a SD card will have the same set-up. Not just Canon.
07-08-2016 10:48 AM
Maybe you bent it too far back; can you move it in opposite direction slightly?
07-08-2016 11:58 PM
04-30-2018 10:09 AM
I know late to the party but I have the exact same problem. How much did Canon charge you for the same ?
05-01-2018 02:44 PM - edited 05-01-2018 02:56 PM
Are you sure it's a bent card slot? or a Jam card slot ?
Check out this video - http://www.photillustrator.com/how-to-fix-your-sd-card-slot/
BTW, there are pins inside a SD card slot. If you use damaged/low quality SD cards, you risk damage the SD card slot/pins.
