10-24-2015 09:17 PM
I just bought a Mini HDMI to HDMI so I can use a monitor but I plug it in and played around. The I swtitched off the stabilizer and the camera died (Like it won't work the batteries are charged I checked with all 3). I can't turn it on at all, I even tried poping open the sd slot to see if the red light blinks and nothing. Please help.
10-25-2015 12:17 AM
@IndaLight wrote:I just bought a Mini HDMI to HDMI so I can use a monitor but I plug it in and played around. The I swtitched off the stabilizer and the camera died (Like it won't work the batteries are charged I checked with all 3). I can't turn it on at all, I even tried poping open the sd slot to see if the red light blinks and nothing. Please help.
Just because you can connect electrical device A to electrical device B doesn't mean you should. A plausible assumption, sight unseen, would be that you applied to the camera a voltage or current draw that it couldn't handle and fried its innards. You can look into getting it fixed, but be prepared for it to cost more than the camera is worth.
10-25-2015 05:20 AM
I have direct-connected my T5i to an HDTV to view recorded video from the camera with no problems, but I do not know what you mean by a stablizer?
Did you use a Canon cable?
10-25-2015 12:24 PM
