T3i/600d Weird Situation
xvxanonxvx
Ok.... I'll try to explain this as best as possible.
I was out last night taking milky way photos.  I use a star tracker that has a bulb feature that I use with my T3i that I then use with my app on my phone and tablet.
Here's where it gets weird and I can not for the life of me figure this out.
When I was taking a photo with my app that connects to the startracker that connects to the camera (following?).... the app fritzed and the bulb was continuously shooting WAY past the mark I set on the app, so the camera was shooting a VERY LONG shot.
So I unplugged the cable from the Star Tracker (AZ-GTI), and the T3i snaps the photo after 60 something seconds (where as i set it to 30 seconds).  I was like weird.... So I plugged the cable back in, the T3i starts another bulb shot, I HAVE NOT TOLD IT TO DO SO... It just shoots automatically.... and will continue to do so everytime i plug in any intervolometer, whether its on the star tracker or a handheld.
Here's where it gets REALLLLY WEIRD......
I now no longer have an lcd screen that works, on any camera settings not M, P, AV mode...EXCEPT!!! MOVIE MODE.... Movie mode works, but only with certain lenses, which helps me none, but i still can't access the menu with MOVIE MODE... All other settings do not work nor do my buttons work...... DISP, Q, MENU, ISO, nothing.....  What does work is that i can change my timer to bulb and the info button ONLY ON MOVIE MODE.
Whats reaaaaallly weird is that when i turn the camera off, the LCD screen shows SENSOR CLEANING...... So the LCD isn't bad, obviously because MOVIE MODE WORKS..... It does work.... ish....
I have done all of the battery stuff, drained it, held the shutter button, blah blah.... I've read literally every article i could get my hands on.  I DO NOT HAVE A SENSOR above the eyepiece, so that's not it either... I CANT TAKE OUT THE INTERNAL BATTERY TO RESET the t3i because its very internal, so i've come to find out.
i purchased a mini HDMI cord, I'm waiting for it to come in, in hopes that may fix it by connecting it to the tv, as a user here did....
I'm posting the video here to show you what I'm talking about, maybe a guru here can figure this out.... i'm beating my head against the wall... I'm not giving up on this, because she still works, seems like she's just frazzled about something.....
NOTE:  I did do a FIRMWARE UPDATE about a week ago to work with stellarmate (astrostuff), It is an official firmware update and it was done correctly.  My suspicions lie there. I would totally revert to factory if I could just access the MENU.
21 REPLIES 21
kombivan
Have you thought about resetting your camera without the screen? Get another 600D and step by step mimic the stepsyou do with the working camera except don't do the reset on the working camers only do that last step on your camera. only problem is you will need to establish a starting point on your camera so the steps of both cameras match until the last step. It it possible you may even have to take the last step with the good camera resetting both as I have no idea what would come after reset, if the screen is still blank.
kombivan
Ilove my450D and 600D no intention of upgrading.
