02-16-2017 04:12 PM
02-16-2017 08:03 PM
Yours is the first complaint I have read in the forums regarding the EF 24-70mm f/2.8L II USM. How are you making a determination that the the lens is slower? It seems to me that you are making a subjective judgement.
If the 24-70 lens is actually slower to focus than the 18-135, then difference is probably small to negligible. Maybe the camera body firmware is causing it to trade speed for accuracy. Most comments about the 24-70 are raving reviews of image quality.
02-16-2017 08:07 PM
If you are trying to shoot a moving subject in continuous shooting mode, there are a couple of factors that can slow it down. First and foremost is having lens correction enabled in the camera. Disable noise reduction settings, too. The idea is to let the camera perform as few extra chores per frame, as is possible.
Another way tip to get the maximum frame rate is to use mirror lockup when in continuous shooting mode.
02-16-2017 09:24 PM
@Waddizzle wrote:Yours is the first complaint I have read in the forums regarding the EF 24-70mm f/2.8L II USM. How are you making a determination that the the lens is slower? It seems to me that you are making a subjective judgement.
The 24-70 is a fairly massive lens. If it does focus slower than the 18-135, that may be why.
02-17-2017 02:40 AM
I would merrily, merrily, merrily trade a small difference in focus speed, for improved focus, any day of the week.
02-17-2017 03:46 AM
02-18-2017 09:10 AM
I have used the ef 24-70mm f2.8L II since it came out. I had version one before it. I have the offerings from Sigma and Tamron.
I can easily say the ef 24-70mm f2.8L II is the best lens made considering the total package. It and the 80D is so much better than the gear you currently have, night and day different. That said the ef 24-70mm f2.8L II is night and day better than any of the other ef-s lenses, too.
Consider this, when you have a faster aperture like f2.8 vs f3.5-5.6, the lens has to be more accurate. If this slows AF down a bit I don't see it. IMHO, if you are considering this move seriously, I would opt for the 6D over the 80D with the ef 24-70mm f2.8L II. Yes there is about a $400 difference but well worth it, to me anyway.
02-18-2017 09:44 AM
@ebiggs1 wrote:I have used the ef 24-70mm f2.8L II since it came out. I had version one before it. I have the offerings from Sigma and Tamron.
The 6D will give you better images, particularly in low light, than the 80D. But, I would still recommend the 80D, or the 7D Mark II, because of their AF and tracking abilities. The 6D is most definitely NOT an action camera. If you can swing the 7D2, then go for it. Otherwise, stick with the 80D.
