12-02-2021 12:31 AM
I have a Canon Rebel T6i that I use for live streaming. The camera is attached to a mini hdmi cable which is attached to an elgato cam link. The quality of the feed is perfect when in "manual mode" in the "on" position. However, when I switch over to "Movie Mode" (or the setting above 'on' with the picture of the video camera') I get a weird blocky video quality (see attached picture). Thanks for the help!Capture.JPG
12-02-2021 07:04 AM
This appears to be interlacing artifacts. Only thing I can recommend is to ensure that your video capture device is set to use the video signal as being output by the camera. Check frame-rates and whether or not interlacing modes are being used.
12-02-2021 08:16 AM
Do you know how to check the frame rates and to check whether or not interlacing modes are being used? Thanks for the help!
12-02-2021 09:02 AM - edited 12-02-2021 09:03 AM
You'll want to check the manual of your camera. Then also the settings you have on the camera or capturing movies. Just a guess, but the frame-rate would most likely be 29.97 (possibly rounded up in the camera's display as 30). Indicators such as 1080i (suffix with 'i') would indicate interlace mode. There should be a table somewhere in the manual stating just what are the possible output signals over HDMI.
