04-26-2022 05:22 AM
I wanted to communicate that when shooting in single shot mode through the EVF, and using the lcd to choose the focus point, the same lock and I had to use the joystick to turn the camera off and on. Firmware 1.5.2
Another question, could i make a suggestion to add in firmware?
I've been shooting with 5D mark III for 10 years, and I use button number 11 (depth-of-field preview button) to switch between AI FOCUS and AI SERVO.
It turns out that in 5D, it would play while keeping the button pressed, and when I released it, it returned to the initial mode! On the R6 when I press the button, it just switches modes. Would you add the two ways in firmware? That is, toggle only, and toggle while pressed?
Regards
04-26-2022 06:45 AM - edited 04-26-2022 11:43 PM
@uran0s wrote: LandstarOnline.comHi,
It turns out that in 5D, it would play while keeping the button pressed, and when I released it, it returned to the initial mode! On the R6 when I press the button, it just switches modes. Would you add the two ways in firmware? That is, toggle only, and toggle while pressed?Regards
Check out this, this might help : https://in.canon/en/support/0400729202?model=4082C
04-26-2022 06:50 AM
Thank you so much for your answer.
Regarding the firmware addon suggestion, where can I do it?
04-26-2022 02:47 PM
Visit Canon USA's Main Page, scroll to the bottom, then click the "Feedback" link under the "Contact" section.
04-26-2022 02:56 PM
Many thanks!
Regards
