05-13-2020 11:17 PM
Hey guys,
Having a bit of a weird problem with my brand new EOS M50. Some of the videos seem to have this weird subtle white stripe going horizontally across near the bottom of the screen.
So far I've seen it in footage with the kit lens and the sigma 16mm EF-M lens so I don't think the lenses are the issue. Apart from that the only thing I've noticed is I don't think I see it in still shots with no motion.
I've attached a dropbox link with a 3 second clip where you can see it pretty easily in about the bottom 10% of the frame.
https://www.dropbox.com/s/wxj8hyrm9vk8jmb/line-hydrant.MP4?dl=0
*note it may not be visible through the embedded dropbox player because of the nasty compression
I appreciate any help. Basically just curious if there is a fix or if maybe I should be looking to return this.
05-14-2020 10:03 AM
Do you see it when reviewed in the camera?
