12-10-2023 02:11 PM - last edited on 12-12-2023 09:10 AM by Danny
Hello everyone,
I would like to ask you for advice regarding sound setting that might close to perfection regarding shooting in forest (nature in general). Even thought, I did almost anything (I could find on internet) to set up my Canon 250D and VideoMic NTG using "DeadCat", I always get background noise and with even slightest wind "DeadCat" does not seems to be working. Everything seems to work indoors, but it is amazingly difficult to find good setting for outdoor.
Please do not judge my choice of equipment, that is what I got, and I have to work with it. Do you have any recommendations? Thank you.
Equipment:
12-11-2023 12:56 PM
Are you using automatic levels for the audio recording on the camera? If so when the sound is low in volume the camera boosts the sound making the wind noise louder. Select manual recording levels and set them for the sound that you want to record - assuming it's your subject talking to the camera.
Secondly what do you have the VideoMic Safety/pad settings and the EQ settings configured as?
Outdoors is harder to record clean audio as there is much more ambient noise around. The best tip is to place the mic closer to the sound source you want to capture, a long headphone extension cable might be enough to allow you to move the mic off the camera and closer to the sound source.
12-12-2023 05:06 AM
That's going to make it tricky.... 😉
I'm not sure what you mean by this. A sensitive mic will always capture any quiet sounds around, particularly if there isn't any loud "foreground" sound to drown it out. If you're recording nature ambience in the forest, then "background" sounds is exactly what you want.
If there's a road nearby, with cars passing, then there's no way to separate that from the general sound of wind in the trees, etc., except to move away from the road. This can be hard -- when recording forest ambience at dawn, I have found that a busy road 1 mile away is clearly audible. The shape of the landscape will help, if there's a hill between you and the road, for example.
If there are planes going overhead, and ruining your recording -- well, all I can do is tell you that field recordists the world over feel that pain.
On the other hand, if there's some specific foreground sound that you want to capture, then get the mic as close to it as you can. Sound falls off with the square of the distance -- get 3 times farther away, and it's 9 times quieter -- so use distance to select the sounds you want. When recording a babbling stream, for example, my usual terchnique is to find a specific spot in the stream that makes a nice sound, then put the mic within 30cm of it.
The point p4pictures made about using manual levels is important too.
Make sure that your camera is set to use the external mic, not the built-in mic. This can be surprisingly tricky with modern cameras. I always put headphones on, then scratch the various mics with my fingernail to make sure which one I'm actually hearing.
The Rode DeadCat is a good choice for your mic. I would expect it to help in a slight breeze; but bear in mind that there is no wind protection that can work in a strong breeze. Even the best blimp windshield will be overpowered eventually.
For what you're doing, you may find it helps to record the sound separately from the video, unless you specifically need them to be synchronised. I don't just mean into a separate recorder, I mean at completely different times. That way you can concentrate on placing the mic to get the best sound, without worrying about it being in shot, and edit out cars and planes, for example. In other words shoot your video, then become a field recordist to capture the sound to go with it.
What you're attempting here is really cool, and I really hope you can get some success with it. Just be aware that recording good quality nature ambiences is surprisingly tricky; people make careers out of this. I made a series of videos on field recording, which might be of help if you're interested: https://moonblink.info/FieldRecording
All the best.
05-19-2024 02:00 PM
Hello, everyone
Thank you very much for being generous to share your lifetime experience. I try to achieve complete removal of background noise (I mean hiss) from the video as I shot it. I do not mean passing car, wind, etc. by background noise I mean this hiss sound or Noise Floor.
As I do not have resources (time and skills and money to buy software) to do any post production, I found my self in loop to find the best setting that I am not able to achieve.
What (sort of) works for me is to set everything to manual on camera with recording levels to almost complete minimum (1) (Sound recording: manual, Wind filter/attenuator - disable) so I can set use mic setting as advised. I achieved satisfactory results with 150Hz high-pass filter and gain set to (12-13). Other setting as High-frequency Boost or high gain (14-15) makes sound "unnatural, screaming, high-pitch). The hissing sound is still in the background.
I tested my setting indoors, and recording is perfect with no "hiss" sound but the moment I go outside noise floor can not be reduced. Anything I can do to ma CANON setting that could help? Thank you.
05-25-2024 07:13 AM
Sound samples (mp3,320), MIC gain 14, 150 High-pass Filters + High-frequency Boost
