01-09-2020 11:03 AM
I own tow cannon 80D camera bodies so I can keep each with a diffenent lense when my subject changes from far away to close. One of my 80D bodies shutter release works fine in automatic + mode but is very slow when I change to AV or other special modes. This contributes to picture blur. What is casing this? Thank you
01-09-2020 11:47 AM - edited 01-09-2020 11:49 AM
" One of my 80D bodies shutter release works fine in automatic + mode but is very slow when I change to AV or other special modes."
This is not enough information for anybody to make a conclusion. First I would reset the camera(s) to factory settings. Menus, tool, clear all setting and all custom settings. Try your shots again.
But with out detailed specifications and settings no one can tell you if there is a problem.
01-09-2020 11:42 AM
Assuming you don't have mirror lockup on, it is usually because of difficulty in focusing.
01-09-2020 11:45 AM
Thanks for the reply but not I don't have it in lockup mode
@kvbarkley wrote:Assuming you don't have mirror lockup on, it is usually because of difficulty in focusing.
01-09-2020 11:59 AM
01-09-2020 12:06 PM - edited 01-09-2020 12:07 PM
Does it it happen when the lens is set to Manual focus?
And it is a Canon lens, right?
01-09-2020 12:09 PM
Slow shutter speed and slow shutter release are two different problems. Just which is yours?
01-09-2020 12:10 PM
01-09-2020 12:15 PM
Great!
Sometimes you just hit a button or setting without realizing it and stuff happens. Glad all is well.
