11-30-2015 01:21 AM
I have a Canon 7D mark 11 that I can not change shutter speed with in manual mode by turning the Quick Control Dial on the back. When I turn the dial, apreture changes instead. The main dial on top also changes the the apreture like it's supposed to.
However, when I push the Quick control button on the back and bring up the setting screen on the LCD, I can change the shutter speeds by rotating the Quick Control Dial and the apreture by turning the main diail. My question is.......
Is there some kind of Hardware/sofware glitch in the camera that's causing the malfunction?
Is there a setting that needs to be changed so that the diails perform the proper functions?
Is this a common manual mode problem and is there a firmware fix for it?
Any help would be most appreciated. Wally
11-30-2015 07:21 AM
@WCurtis wrote:I have a Canon 7D mark 11 that I can not change shutter speed with in manual mode by turning the Quick Control Dial on the back. When I turn the dial, apreture changes instead. The main dial on top also changes the the apreture like it's supposed to.
I suspect you changed a settings in the custom functions to create this behavior. Try resetting your custom functions and see if the problem doesn't resolve itself.
Normal behavior for Canon cameras is that the main dial near the shutter release is the shutter speed and the rear dial is the aperture.
You can swap these two using custom functions.
11-30-2015 10:44 AM
Wally do a "Clear all settings" and try again. (Under the Tools tab)
11-30-2015 03:40 PM
Yes indeed, you were right on with your answer. Changed the function in customes setting and solved the proplem. Thanks for the help. Wally
