Shutter delay eos rp
Refsoc
I have a new EOS rp.in automatic mode when the shutter is depressed there is a 10 sec. Delay prior to the picture being taken. You can see the timer in the viewfinder.
kvbarkley
Not the interval timer, the drive mode. It is set for a ten second delay to allow for old school selfies. It is one on the basic settings on the quick control screen.
7 REPLIES 7
Anonymous
Not applicable
Looks like you've got the self timer set, set the drive mode to another mode.
Well going to my menu screen interval timer is disabled. I changed to a different program (P) same delay
kvbarkley
stevet1
Refsoc,
What you are looking for is a Drive Mode.
Apparently, the RP does not have the Drive Mode in the menu settings, but as I understand it, if you hit the Q button, the Drive Mode shows up on the left hand side of your settings screen.
Look on page 414 of your User Manual here:
https://www.manualslib.com/manual/1860359/Canon-Eos-Rp.html?page=414#manual
it shows you how to select your Drive Mode.
What you want is a single shot, not a 10 second time delay.
Steve Thomas
Tintype_18
Download the manual.
John
Thank you that corrected it
Waddizzle
Change the setting in the lower left corner to the single square.
