04-01-2021 02:13 AM
I have many vintage primes of 4 brands. I would like to have some of them, 85mm f1.4 & 90mm f2.8 micro, mounted on T6s.
It was said ten years ago that it was impossible for such combinations because of the mirror. How about it today? Anyone has successful experiences?
Thank you.
Dianoban
04-01-2021 05:40 AM - edited 04-14-2021 05:37 AM
Old film SLR lenses change a little when you put them on most digital SLRs. They actually zoom in a bit further, as digital SLRs only see the center-half of the picture. This is rarely a problem for long zoom lenses, as they will zoom even further on a digital SLR.
04-01-2021 09:20 AM
@William_27 wrote:Old film SLR lenses change a little when you put them on most digital SLRs. They actually zoom in a bit further, as digital SLRs only see the center-half of the picture. This is rarely a problem for long zoom lenses, as they will zoom even further on a digital SLR.
Not quite. You are confusing Crop Frame and Full Frame DSLR's. An older EOS lens from the film days will have the exact same field of view on a full frame DSLR as it did with 35mm film.
For the OP, If you can get the adapters to put them on, you might lose infinity focus, but it will still work.
04-01-2021 09:48 AM
"For the OP, If you can get the adapters to put them on, ... but it will still work.
I agree and it can be fun
but it is not worth doing for any real application. Current digital lenses are so much better, even the least expensive ones. I've tried converting or adapting about everything that can be adapted. So ,I certainly can't say don't do it but don't expect much from it.
04-01-2021 11:20 AM
Yes. There is some change. And I am thanking that the change is to my benefit. Example, I have a lens 1:1.2 f=55mm, it will become 88mm on T6s, just right for shooting portraits.
Thank you for trying to help.
Dianoban
04-01-2021 11:28 AM
Thank you.
Yes, I can buy adapters but I can not be sure whether the combination will cause any trouble, namely, old lenses interfer with the flipping movement in the T6s. This was said years ago. Do you whether this is still the case?
Appreciate.
Dianoban
04-01-2021 11:40 AM
@ebiggs1 wrote:"For the OP, If you can get the adapters to put them on, ... but it will still work.
Thank you.
I totally agree with you that old lenses do not deliver as good image quality as the new lenses do. But 1). just for the fun & 2). my interest of photography is for fun, not demanding for quality as long as the images are "acceptable" since I am not any professional. I use many vintage lenses on my Sony a7ii. Shooting manual. Somehow I feel like shooting film.
Appreciate your good advice.
Dianoban
04-01-2021 12:16 PM
" 1). just for the fun & 2). my interest of photography is for fun,..."
I say go for it.![]()
04-01-2021 12:26 PM
"I can not be sure whether the combination will cause any trouble, ..."
Of course I can not know every single combination there is available but I don't know of any adapters on old lenses that cause any interference. It is possible to do some "surgery" (not going to tell you how though) on ef-s lenses so they will mount on a ef camera and that can cause some issues.
Like I said above I have tried about every adapter there is and I never had any real trouble except like I mentioned the results are not very good. Actually pretty poor but our standards may be different. The best adapter by far is the ones made by Ed Mika. I don't know if he is still making them but they work and they do a good job. As good as can be expected anyway. Keep in mind most of the available adapters are of poor optical quality and mostly they are the problem. Not the old lens.
04-01-2021 01:39 PM
If you get the adapters to fit on an EOS lens mount, just make sure that it doesn't protrude into the body of the camera.
