Saving edited images
olympiarocks200
Hi everyone! I'm the brand new owner of a Canon 90D. I love the image quality I'm getting so far, but I'm having a few problems with editing- if, after copying files from the SD card to computer storage, I try to edit too many at a clip, they won't all save. I'm able to get them all done by editing/saving in batches (and I never delete the original images off the card before they're all saved, or try to edit them on the card- learned that the hard way!), but I'm wondering if this has to do with the size of the files- previously, the cameras I used produced files that were a third the size this beast makes. Is there anything I should be doing to be able to save the files with more ease?
13 REPLIES 13
Office wasn't designed to edit photos.  As John pointed out above, try Canon's free software instead.
While not free, I can also highly recommend Adobe Lightroom.
Ricky
Many thanks! Lots to learn with this new machine. 🙂
IF you are editing RAW image files . . .
and IF you are using Canon's DPP4 RAW editing software . . .
DPP4 is a bit vague in it's descriptions of "SAVE" and "CONVERT & SAVE". Clicking SAVE will only save the edits you've made for a particular RAW image file. After editing, if you wish to create and save a jpeg copy of the image you need to do a CONVERT & SAVE. This can be done to a single file or you can choose multiple files and batch convert them.
Your PC should have a bit more "oomph" than the most basic models might have. It helps to have a decently fast processor (Intels seem to work better than AMDs for some reason) and maybe some more RAM. You may or may not need to add a graphics card of some type, especially if you're making lots of more complex edits and regularly converting large batches of RAW files.
Also, at one time, things seemed to get bogged down if you put a more than 50 or so RAW files in any one folder. I think this may have been more of an issue with earlier versions of DPP.
Thank you- I'm in for quite the learning curve here I suspect. Between the art, the science, and the technology, photography will give your brain a killer workout!
Holiday
