11-27-2021 11:27 AM
I want to use my SL3 for video with Zoom, Discord, and Skype. I have it hooked up via USB and it is ok but I'm wondering if there's a way to use the HDMI port for better quality. I think I might also need a capture card but I'm not sure. The HDMI ports on my computer's video card are outputs for a monitor, not inputs for a device. Would the right cable do it? Mini HDMI to USB? I'll be teaching guitar so I need the video to be as clear as possible.
Thanks in advance for any advice.
Jon
11-27-2021 02:39 PM
The Canon EOS Webcam Utility only uses the USB port. IF the SL3 can be set for "Clean HDMI" output, then you would need some sort of HDMI capture device. According to the volume of YouTube videos about Clean HDMI and SL3, it should be just a matter of going into the menus, and Turing it on.
11-27-2021 02:39 PM
11-28-2021 01:09 AM
11-28-2021 07:56 AM
Thank you so much. I think I have this figured out now.
