SL2 shutter issue with off camera flash
oanhlai
My canon SL2 would stop closing its shutter after a while when I shoot with off camera flash. It always start out fine but after an hour or so it would act up. The shutter would just freeze in an open state. Switching between live view and view finder would not help closing it. Not even turning off the camera or switching to different modes. The ONLY thing that would close the shutter is to release battery and put it back in. I’m new to issues with camera so I may have used incorrect terms to describe it. Hope someone with more experience can give me some insight. Thank you for reading.
11 REPLIES 11
Moderator
Moderator
Hi, oanhlai!
So that the Community can help you better, we need to know exactly which flash you're using. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
I’m using Godox ms300.
Hello oanhlai can you still see through the view when the camera acts up. It sounds as if your mirror isn't returning to the down position for viewfinder shooting.
-Demetrius
EF 16-35mm F/2.8L III USM, EF 24-70mm F/2.8L II USM, EF 28-135mm F/3.5-5.6 IS USM (Retired 8/2007-11/8/2022), EF 50 F/1.8 STM & EF 70-200mm F/2.8L IS III USM
EOS 40D (Retired 8/2007-5/26/2022) & 5D Mark IV
430EX III-RT & 600EX II-RT
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
I would still see everything on the live view. I think you are correct the mirror would stay up when I remove the lens to check it. Normally when I press that little button to switch between live view and view finder you would hear the click sound but when it acts up the shutter wouldn’t move.
What shooting mode are you in. It sounds like mirror lockup is enabled in the camera menu.
-Demetrius
-Demetrius
I shoot manual mode. It only happen when I use off camera flash. I have never noticed mirror lockup in menu but I would check again. What does that do and why there is such a feature? It’s canon sl2 so it doesn’t have a lot of features like other more advanced models.
Mirror Lockup is used for long exposure bulb photography pictures. This reduces any camera shake and image blur. This is setting is best used when the camera is a tripod with a long shutter speed ie more than 30" with the mode dial set to "B". Or on older cameras "M" mode.
-Demetrius
-Demetrius
I see what you are saying, though I don’t think it was because of the setting. I have checked and my camera doesn’t seem to have that feature either.
Are you using live view with this off camera flash setup. Non-Canon speedlites won't fire in live view only Canon speedlites will.
-Demetrius
-Demetrius
Friends and Family
