SD card not working in EOS Rebel T7
mbreaux73
I purchased a refurbished Canon Rebel 17 from Canon. I purchased an SD card and it’s not working or formatting. Need suggestions on which card to buy.
11 REPLIES 11
Moderator
Moderator
Thanks for joining the conversation, mbreaux73!
While we haven't made a camera with the model name "Rebel 17," we have made models called the EOS Rebel T7 and the EOS Rebel T7i.  We recommend that you take another look at your camera and double-check the model number so that we can know exactly what you're using.
Thanks and have a great day!
EOS Rebel 17 is the model I received
EOS Rebel 17 is the camera I received
It is a EOS Rebel T7
@mbreaux73 What kind of SD Card did you purchase a full sized SD Card or a Micro SD Card in an adapter. An adapted Micro SD Card causes all sorts of problems. Also what capacity is it. Your particular camera doesn’t work well with SD Cards larger than 32GB (SDHC). So if you’re using a card 64GB (SDXC) or larger than that your camera will have problems working with it.
-Demetrius
Bodies: EOS 40D & EOS 5D Mark IV
Lenses: EF Holy Trinity, EF 50mm F/1.8 STM, EF 70-210mm F/4 & EF 85mm F/1.8 USM
rs-eos
Also, what brand of SD card did you purchase, and from where? There are cases where counterfeit cards have been sold, for example, on Amazon.
Ricky
I previously purchased 64 GB SDXC. I’m a beginner . Thank you for the recommendation, I will purchase the 32 GB SDHC
@mbreaux73 Make sure it’s a full sized SD Card. Also beware of counterfeit SD Cards sold on many online marketplaces such as Amazon. I personally purchase SD Cards on B&H Photo NYC’s website.
-Demetrius
Yes I purchased a San disk on amazon
