SD Card recovery
wIbz
Hey,
I have an 80D and I formated the card by mistake, I really like the photos that i took and I would like to know if I could recover the photos.
I use a Lexar SDHC 633x/95MB/s 32GB.
kvbarkley
VIP
VIP
See if Lexar has recovery tools. It also depends on how you formatted it. If you did a low-level format, you are probably out of luck.
7 REPLIES 7
kvbarkley
VIP
VIP
As long as you haven't recorded any new images you should be OK. From my experience even low level formatting doesn't overwrite images.
wIbz
Thanks guys, I didnt do a low-level format, so I should be good, I will try to get home ASAP and recover the photos, Thank you once again!
And if you don´t have any luck finding a software, Photorec is free and open source.
Hi Can you tell me how to recovery SD HC low-level formatted card?
i really appreciate if you can tell me how to recovery low level format 🙂
If you've done a low-level format, your files are probably not recoverable.
andrii-jsk
Oh **bleep**, that sucks. But don't freak out just yet, there's still a chance you can recover your photos. When you format an SD card, it doesn't immediately wipe out all your data, it just makes it tougher to find.
There are some software options that can help you get your photos back, like Recuva or PhotoRec. Both are free, by the way. If you need a more commercial one, you can try Disk Drill, or R-Studio/DMDE if you need something more tech-savvy. Just download and install one of these programs on your computer and follow the instructions to scan your SD card and recover your photos.
Just keep in mind that whether you can recover your data or not depends on a few things, like how long ago you deleted your stuff, how much new data you've added to the card since then, and the condition of the card itself. So, try to recover your data as soon as possible and don't add any new data to the card.
[Commercial link disabled.]
