11-10-2017 09:48 AM
Hello,
I ususally use this feature when shooting photography: Record to multiple cards (5DIV).
Card 1: the work.
Card 2: a backup of the work.
I tend to use cards (1 and 2) with the same size in order to change full cards at the same time, while working.
Never had a problem.
For video 1080p or 4K will I be able to use the Record to multiple cards function or the video is recorded only to one card?
Thank you very much.
11-22-2017 08:01 PM
Hello Cunha,
The options under [Record func+card/ folder sel.] > Rec. to multiple affects still images only and do not apply to video recording.
For 4k recording you would need either a UDMA 7 100 MB/ sec. or faster CF card or an UHS-I speed Class 3 or higher SDHC/ SDXC cards. The camera is not compatible with UHS-II SDHC/ SDXC memory cards.
11-22-2017 08:01 PM
Hello Cunha,
11-23-2017 12:31 PM
Tim; solved ,-) Thaks again.
Best regards.
