Rebel T7i still shots suddenly blurry
squeezy
Hello,
I use my Rebel T7i with a Tamron 60mm f/2 macro lens for nail polish photography. While shooting, my shots suddenly got blurry and I haven’t been able to get it back to its crisp shots.The two images are shot at the same settings (ISO 800, f6.7, 1/500). I didn’t change the settings but I may have moved my light a bit. In any case, I’ve tried getting shots of different objects, a differently lit area in the room, changed settings, cleaned the lens…it’s still hazy!
I don’t know what else to do to fix it.
5 REPLIES 5
squeezy
Forgot to add the images
kvbarkley
What is the minimum focus limit of the lens, you might be right at the limit.
The minimum is 9 inches. I did try adjusting the distance from different subjects and they’re all coming out with the haze.
kvbarkley
I suggest you use the option to review the focus points:
I’ll try that! Thanks!
