08-04-2023 09:18 PM
My camera was working fine and yesterday it would not work. When I powered it up the back display was black and none of the functions on the back would work. When I looked through the view finder there was a busy signal. It acted like it wanted to focus but wouldn’t and the shutter would not release.
I changed from AF to Manual focus and still no joy. I changed lenses and still the same issue. Changed SD cards still no joy.
I can’t change settings because the back display does not work nor any of the functionality buttons.
Please advise on what to do to resolve this issue. Thanks in Advance. Jim R.
08-04-2023 09:22 PM
Remove the lens (and re-install the protective cap in its place). Remove the SD card. Remove the battery, wait for a bit, then reinstall and power on. If you're able to now get to the menus, try performing a camera reset.
If the camera though fails to work with lens and memory card, or fails after you re-attach/re-install those items, probably should call up Canon to schedule a repair.
08-05-2023 10:42 AM - edited 08-05-2023 10:43 AM
What is the storage capacity of your memory card?
Are you using full size memory card or a micro-SD card with an adaptor?
Did you format the memory card in the camera prior to first use?
08-05-2023 02:15 PM
Yeah it didn’t work. I took it back and exchanged it. I hope I have better luck with this one.
